Access Message at Render time
  • Access Message at Render time
    Hello everyone,
    Guys, i am trying to figure out if this is possible to access messages that v-ray generates during render time.
    i need to trace when image file is saved and where. if some one know of a way to do so - that would be great
    -- in general, what i need as my end result, is to pass a message to renderpal that certain frame finished rendering, and thus it would be able to update the image-previewer (new feature in recent release or renderpal)
    thanks!
    The messages are written to the V-Ray log file, so perhaps you can check that. You can also force V-Ray to print all its messages to the backburner server - let me know if you need more info on that.
      hey, thanks for getting back to me so quick, yeah , i saw that it prints those to LOG file, but it generates the LOG once the rendering has been completed.
      at our company, we are using Renderpal, not backburner. so i was hoping to be able to "see" the output as it happens.
      do you know of any way to access the "log" LIVE ?
        The file is being written continuously and you can use tools like "tail" to see the latest messages. In any case, I assume that Renderpal still shows you the console output of 3ds Max, no?
          really? i thought that file was written once rendering was completed.
          And no - unfortunately, 3d max when rendering using vray does not produce any output, (meaningful output).
          i will try getting to the file and read the tail, i will let you know i got any luck
            Well, try typing the following in the MaxScript listener before saving the scene and see what kind of output you get:
            Code:
            renderers.current.system_vrayLog_ccToDebugger=true
            and see what output you get from renderpal.
              running this command in Listener gave me FALSE as an output. Is there anything as alternative i should be getting>?
                Sorry, I forgot a =true at the end - I've updated my post. Executing the command will cause the V-Ray messages to be propagated to the output of 3dsmaxcmd.exe - hopefully this is what renderpal is using.
                  vlado,
                  this is perfect! It worked, i get exactly what i need from the output by filtering for a string "Successfully written image file", and it works.
                  How and where did you find out about this command? i was looking at the renderer.current but, didn't see anything for vray...?
                    Eh, I put it in V-Ray
                      hahaah, fair enough Vlado, once again, thanks! this is a good breakthrough with our pipeline development here at the studio :0)
