Lights don't work when copied
  • Lights don't work when copied
    Only the original light has light output in render. All other lights were copies of the working component yet none render any light. Is there a setting i am missing.
    Thanks,
    r
    This shouldn't happen in 2.0, what version of V-Ray for SketchUp are you using?
    Devin Kendig
    Developer
    Chaos Group
      Hey Devin,
      I am using SketchUp Pro and V-Ray for Sketchup 2.0 so I am not sure what the problem is.
      Thanks,
      R
        Originally posted by RYANFITZG View Post
        Hey Devin,
        Thanks,
        R
        What plug in did you use?
        Have you check the light before you render it?
        Regards
        Yoshi Ikeda
          also, what type of light are you making copies of? I just tried the point light, and had no issue.
          Devin Kendig
          Developer
          Chaos Group
            I've actually seen this or something similar, but haven't been able to repeat it. As best I can recall, I opened a model with lights created either in a much earlier beta or 1.49. I think I was in RT and I tried to copy the lights, but the light definitions lost their vray lights properties so I couldn't edit them. I think it was spotlights. Actually, they might have still rendered but just not at the values I wanted, so it might not be exactly the same issue. I think I just restarted the model and didn't see an issue again. Wish I had more to go on but thought I'd mention it nevertheless.
              I am making copies of a basic spotlight. I have rebuilt the lights multiple times, copying and not copying. Each time it only renders the first light built. I all other lights are working in multiples.
                not seeing that in my test. I can copy spotlights with no issue. this happens in a fresh scene?
                Devin Kendig
                Developer
                Chaos Group
