BugSplat RC Resource DLL not found
  • BugSplat RC Resource DLL not found
    Hy Everyone,
    It happened when i render one scene and the vray progress windows shows between 50 to 70% and suddenly the render stop and one window showed " BugSplat RC Resource DLL Not found"
    Anyone please advice me how to fix the problem..
    I have urgent deadline...and it is been couple of days I keep trying without result
    Regards
    Yoshi Ikeda
    check your memory usage. If you're getting close to 4gb of ram being used by the SketchUp process, then you're going to need to do a few things to work around SketchUp's memory limitation of 4gb.
    1. render to vrimage
    2. if you're on a 64bit machine and have more than 4gb of ram, you can try rendering via 64bit DR only.
    I hope that helps
    Devin Kendig
    Developer
    Chaos Group
      I hope that helps
      Hy,
      Thanks for reply,
      It is work thanks!
      Regards
      Yoshi Ikeda
