Hello can someone please help me? I am getting some black lines visible on my darker textures for example on the lower part of left hand side door and the floor- there are black lines - these are not part of the texture I have tried all sorts to get rid of them and I cant seem to lose them anyone know what they are?
Black lines issue
Black lines issue
Hello can someone please help me? I am getting some black lines visible on my darker textures for example on the lower part of left hand side door and the floor- there are black lines - these are not part of the texture I have tried all sorts to get rid of them and I cant seem to lose them anyone know what they are?Tags: None
may be you should make your image brighter, because is too dark and cannot see the problem partBest regards,
Jackie Teh
3ds Max 2023, V-Ray 7 Hotfix 1 [7.00.04 build 00000]
It's incredibly dark on my fully calibrated monitors. Too Dark.
I'm not really sure what I'm looking at on that last image?
I'm just guessing here, but if you image is really that dark in that specific corner, it's probably not getting enough samples and leaving some residue from undersampling.
I would probably lighten up that particular material, setup a multimatte for it, and then darken in again in post if needed.
i can see this line also on the left wall, close before door and down next to floor. but the more i look up, the less i can see this line.
and this "line" is on the right also next to window following the jalousie. some artifact of jpeg compression?
