Hi
I noticed when tweaking a simulation, that in a second run Phoenix FX emitted on objects that were not assigned in sources anymore.
So I ended up deleted all of my sources in the scene and started the Simulation once again. Still, particles kept emitting inside the cage.
Why is it doing that? There is no source, so not even an emitter object assigned, still inside the Phoenix FD cage particles emit from the shape of the object that was assigned in the source I deleted.
Does PhoenixFD add up discharged particles with every new simulation?
I got velocity checked, does it have to do with that?
Many thanks in advance for clarifying!
Chris
Chris
