matt object problem
  • matt object problem
    Hi, attached is the problem i have met recently after i change all my object to matt object except car and people, when i press render the RGB Color is look like this image,
    please help, thank you.
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    Could you post a simple scene setup that reproduces the issue?
    As far I can see, most of the splotches are in the area below the trees.
    Is it better when you add an override mtl?
    Tashko Zashev | chaos.com
      Originally posted by tashko.zashev View Post
      Thank you for your reply, i haven't try the override mtl yet,will give it a try.
      at this point, i made my matte object by changing their Vray object properties, so may i know where should i apply the override mtl to?
      Jackie Teh
        You can use the Override option in Global switches tab to add regular V-ray mtl. It will override the matte objects as well (they will still work as matte, but calculated using the new mtl.)
        You can first try to override the leaf material only and run a test render again. I believe this will make the things better.
