Hello guys,
It's been awhile I've been trying to solve this problem but no solution so far, if someone can share their knowledge on lighting in Vray for SketchUp, it would be useful.
the situation:
the issue:
I have been also testing with the Override Material option, using white and grey color for the material override, these are the results:
white:
grey:
As you guys can see, with the grey color, the "effect" that causes the problem is like 99% gone, so i guess this might have some relation with light reflection in white surfaces.
and thanks in advance.
ps:. I also use Vray for 3dsMax, and the same issue is ocurring there.
the situation:
the issue:
white:
grey:
