PhoenixFD problem Unable to render foam and splash
  • PhoenixFD problem Unable to render foam and splash
    Hello, im using max2014 and the problem is, it simple refuses to render foam and splash. I watched a tutorial video, everything works fine, foam builds up like in the tutorial video, but when i render it, i only see the water and nothing else.. What could be the problem?
    by default phoenix renders only the grid content, the particles are rendered by additional object PHXFoam , create one and everything will be ok.
    which tutorial video you have in mind?
    ______________________________________________
    VRScans developer
      Hmm, it still does not work. Maybe i forgot something, but i created a PHXFoam and nothing changed.
      Here are some screenshoots from the render and viewport.
        I don't know Max, but in Maya we have to connect the PHXFoam to the Foam and Splash to have it rendered. You can also try to increase the size multiplier, sometimes it renders so small that you don't see it.
        www.mirage-cg.com
          there is a button "particle system" above the parameters UI, select the simulator with it.
          VRScans developer
            OOkay, thanks for the help, its working now.
