Is there anyway to set the defaults to expert for 3.0?
Vray 3.0 Expert settings by default?
Originally posted by jneilon View PostIs there anyway to set the defaults to expert for 3.0?
Yes, this is something that we can improve to the V-ray 3.0 UI. It will be considered with our developers.
Meanwhile you can create a default 3ds max start up file using the following steps:
*) open 3ds max
*) open V-ray render settings
*) right click on the UI mode (Basic) and choose Switch all to expert
*) save this scene as maxstart.max to your default scenes folder
You can go to Customize\Configure User Paths to figure out where your scenes folder is pointed to.
Thanks, this helps. Although it does not work when creating a new scene it defaults back.
I realized there is a new area in Vray 3.0 under system that allows for saving render presets but it does not make it default unfortunately. I am hoping I will find a config or ini file somewhere that I can just edit.
I like the idea of easy for beginner users but after using Vray for 9 years I like to see all the settings by default.
Originally posted by jneilon View PostThanks, this helps. Although it does not work when creating a new scene it defaults back.
Another solution with maxscript, so each time max load a file it turn all VRay panels to expert :
Just put the code in a startup script.
function setVRayExpert =
vr=renderers.current
vrName = vr as string
if findString vrName "V_Ray_Adv_3" != undefined then
rdropen = 0
if (renderSceneDialog.isOpen() == true) then rdropen = 1
renderSceneDialog.close()
vr.gi_ui_view = 2
vr.irradmap_ui_view = 2
vr.lightcache_ui_view = 2
vr.caustics_ui_view = 1
vr.colormapping_ui_view = 2
vr.system_ui_view = 2
vr.options_ui_view = 2
if (rdropen == 1) then renderSceneDialog.open()
clearlistener()
callbacks.removescripts id:#VRayExpertPostLoad
callbacks.addscript #filePostOpenProcess "setVRayExpert()" id:#VRayExpertPostLoad
Originally posted by vlado View PostThis was a spam bot I think...
