Textures not rendering in blocks defined 'by parent'
  • Textures not rendering in blocks defined 'by parent'
    I just realized that if I assign a textured v-ray material to a block (which had its components material set as 'by parent') it doesn't display the textures when rendering. They are displayed however in 'rendered' viewport mode.
    The same setup renders fine however with the Rhino renderer, when assigning to the block either a vray material or a Rhino material. So Rhino renderer is able to recognize and render vray textures, which is an added bonus.
    I uploaded a sample with two instances of the same block, one with vray material and the other with Rhino material.
    It should also be noted that the mapping coords established in Rhino before making the block become lost when switching to Rhino renderer but they are respected when switching to Vray renderer.
    Sample is here: https://www.dropbox.com/sh/re5fnoguyl5xuun/ylclcQ0sUp
    Using Vray 2 and Rhino 5 SR6
    Thanks
    www.marinevisuals.com
    3D Visualization for the Marine Industry
