render only shows 3 light sources
  • render only shows 3 light sources
    I've got the vray plugin working, basically.
    I'm saying basically, becuase when I've added (and configured) all IES lights, and have rendered the view the render only shows 3 lightsources!
    I've searched, read the manual but can't seem to find the solution to the problem.
    am using sketchup version 14.0.4900 and vray plugin version 2.0.
    Hope anyone can shed some light on this issue I'm having!!!
    thanks!!
    I think it's a demo limitation.
      Hi, There are a number of reasons this could be happening. Your IES Lights may be competing with the sun and may have to be turned way up to be visible. Your cameras shutter speed may be set too high. You may also be inadvertently placing the light inside a piece of geometry, causing the light not to show. Try turning off your GI and background under your Environment tab ad rendering. This may she light (pun intended) on your IES Problems. If you still have trouble please email your issue and scene to support@chaosgroup.com. If your scene is too large use a link to your file with your preferred file sharing method.
      Best,
      Ted Vitale
      V-Ray for SketchUp
      Product Manager | V-Ray SketchUp
      Chaos Group
