Z Depth Rendering of Fire/Smoke
  • Z Depth Rendering of Fire/Smoke
    Hi there!
    Sorry if it has been asked before, but is there a way to render a Z Depth Pass of PhoenixFD Smoke?
    PhoenixFD Liquid works just fine in Vray Z Depth, but when I tried rendering my Smoke Sim in PhoenixFD in the ZDepth Pass straight away, it is just displayed white, which is a pity cause it makes the ZDepth sequence uselss. Is there a way to get that Z of let's say a cloud?
    Thanks in advance!
    I think you can get z depth with the geometry mode both in Max and Maya. AFAIK, 3ds max do not support volumetric z depth yet.
      Thanks. As a temporary solution I figured I use a vray environment fog with the fog color set to black. Actually it seems to work quite well, but I guess it's far from being a clean solution.
        i thought vray 3 does deep rendering. wouldnt pheonix smoke be affected by that?
          you mean deep export? for deep export you have to render in geometry volumetric mode
          VRScans developer
