VRayMtlWrapper error
  • VRayMtlWrapper error
    Dear Support Team,
    Kindly refer link below.
    http://a360.co/1jKb4hZ
    When I using VrayMtlWrapper for rendering in version Vray adv 2.50.01, the object is ok.
    But when I using VrayMtlWrapper for rendering in version Vray Adv 3.00.07, the object disappear.
    Is there any problem? Anybody know about it?
    Thank you !!
    There is a bug with matte-surface functionality in version 3.x this includes VrayMtlWrapper and VrayObjectProperties.
    Fortunately it is already fixed but not officially released, hopefully it will be available in the next official service pack.
      Oic, nobody reliase this problem. Hopefully the next service pack able to solve this problem.
      Thank you!!
        Hi all,
        i have noticed this also, and as much as i have tried to find if it is solved i just cant...al the threads just stop at some point with no fix mentioned...
        is it solved? thx
          Originally posted by tambyra View Post
          Hi all,
          is it solved? thx
          Can you post some render images or the scene file you have problems with?
          I believe that the original issue in this topic was fixed for the 3.1 Service pack. I have also noticed that the scene file Kwaikeong posted uses standard 3DS Max material with Raytrace map inside the V-Ray material wrapper node.
          Which V-Ray version you are using?
          Tashko Zashev | chaos.com
            Originally posted by tashko.zashev View Post
            hi, thx for a fast reply, i have started a thread here http://forums.chaosgroup.com/showthr...pper-situation where i tried to explain my situation the best i could, the thing is that i cant get an object and its shadow and save it as PNG so i can use it more easily later...
Name:	lap top bez pozadine standard.png
            results like this i attached is what i get most of the time... i use V-ray 3.00.07
            is "specific" isue fixed or am i doing something wrong...
            i spent 2 weeks trying all the different combinations ant the results are similar...
              Are you using Sun and Sky for this scene? Can you post a sample of your scene just to check it out?
              There was a similar problem discussed in that thread :
              http://forums.chaosgroup.com/showthr...ght=matte+room
              I think that the best approach is to render separate passes for the room, items and shadows.
              By the way, you can download and update your V-Ray to the latest version 3.10.03.
                i am using a dome light but have tried also a plane and sphere...i have updated and will try it in a few days and post to let you know
                thx again for a reply
