Emissive logo with accepting transparency as blank - is it possible
  • Emissive logo with accepting transparency as blank - is it possible
    Hello,
    Im trying to create an EMISSIVE LOGO, but when I use EMISSIVE LAYER all my transparency from the logo (PNG file)lights up.
    Is it possible to make an emissive logo with Vray in the way Vray also accepts transparency as it is and not lights it up ?
    thnx for advice
    Hi Kuzla
    You need to use an alpha mask on the transparency option of the emissive material. If you have a diffuse layer with a texture, you will have to use the same alpha mask on the transparency slot of the diffuse layer too.
Name:	7-17-2014 12-15-55 PM.png
