PHX Foam object render passes?
  • PHX Foam object render passes?
    Hi there,
    I am using the PHX Foam object to create a mass of bubbles and what I really need is separate elements (refl,spec,etc.) but I can't seem to figure out if this is possible or not?
    I am using the bubbles setting and have tried rendering as geometry, which gave me a velocity pass, but nothing else?
    Any help would be much appreciated.
    Cheers
    Alex
    Also forgot to mention I am in 3dsmax..
      you are right, i just tried it and seems that reflection and refraction elements are not generated. ok, we have to fix this
      ______________________________________________
      VRScans developer
