vray 3.0 bug! with visibility
  • vray 3.0 bug! with visibility
    hi,
    I have noticed a bug with vray 3.00.07 Please can you have a look at this?
    When rendering with visibility (visibility is located in object properties) on mesh at 0.0 (hidden / off) the beauty renders correctly. But rendering with passes the hidden geometry appears in these passes:
    light select,
    Normals
    Sampler info UV
    Diffuse
    GI
    VrayRenderID
    SSS2
    VRaySpec
    Passes that render ok
    Passes such as, vray extra tex VRaydirt plugged in, reflection, Raw reflection, Muiltmate, Zdepth render correctly
    We need to use vistably as its a quick way of animating hiding objects, we are animating 0.0 to 1 so on/off, no values in between. Checked curve editor and is showing keys at 0 to 1 in one frame no in-between values.
    we are using vray 3.00.07 and 3ds max 2014
    Ravi
    Would it be possible to attach a scene for this? I get the object hidden for all render elements, but I might missing something.
    Tashko Zashev | chaos.com
      Originally posted by tashko.zashev View Post
      Thanks Tashko,
      i found the problem, its 3ds max not vray,
      when checking the object in object properties it displays visibility as 0
      but looking in the curve editor carefully at frame zero was set to one. Its a 3ds max problem.
        Ahh, good to know that. Thank you for the update.
