Hello everyone,
I have been facing this issue. I've isolated it down to a single area light. So long as it glances around the surface. This happens.
I've gone through all the settings, and I am using a linear workflow.
The below did not help -
- increasing sample counts on lights subdiv value does not work
- light cut off threshold does not work
- not caused by rec tex
- not caused by rec tex resolution
- Problem isolated to reflection specifically
What is causing this? Any ideas? Thank you.
