bug visible to camera
  • bug visible to camera
    If I disable the properties in the Phoenix "object Properties"> "visible to camera" we see only a reflection / lighting.
    But if I put in the foreground plane with opacity map that simulates a dirty lens. That visible to camera does not work.
    can't reproduce it here, seems to works correctly. can you put a simple box beside the simulator and to check how the same option behaves for it?
    VRScans developer
      You are right! This is not a phoenix, the box is also seen!
      Perhaps vray calculates it as refraction of plane. And not as objects with the option visible to camera.
      A pity, now will have a compositing dirty lens.
        Can I use only the light from the simulation of the Phoenix. In order not to be seen of the fire and smoke?
        Maybe there is a way?
          i think you gave up too fast
          as i said, i was unable to reproduce the problem, perhaps your material put on the plane is not just transparent, i tried with standard material with opacity map, and the objects behind it was visualized properly. as developer i know that vray keeps the same ray when goes through semitransparent object, but the refractive objects are producing secondary rays, that are considered not to be camera rays.
          VRScans developer
