problem importing materials
  • problem importing materials
    Im using sketckup 2015 and vray 2.00.25244
    when i import a new material the texture does not appear on model there is just a gray color(however there is a bitmap assigned in diffuse) . there is no problem in render but how can i edit the texture in this way (no texture, no texture position!)
    Do you have a solution for this problem? I have the same result!
      Do you have a solution for this problem? I have the same result.
