Hello.
I try to create a scene and fluid bottle - Wine.
But, in a lesson on the video you can see that the water is moving uniformly.
I tried to make two choices:
Using a helpers PHXLiquid,
and PHXSource.
At first I got a fountain out of the bottle,
after already began to change viscosity, wettability, SPF.
When using PHXLiquid:
I almost reached the uniform motion at disgarge 100 to 0,
but the water began to evaporate in the middle of the frame rate.
I change the Drying time, nothing really changed,
when cleaned wetting, can control the height of the flow, a little spray,
But gradually and I have not received.
When using PHXSource:
As I understand it, this source has more flexible options,
I can use either fuel or fumes.
when put wetting, water all the time running up to fountain,
I almost reached, a uniform flow (as in video viewport) not to render, but can be seen with the fuel, there goes another faction, or any parameter,
which allows to render plaque on the bottle as if anointed paint (can not see anything).
More why something does not match the size of the water in viewport and render.
Thank you.
PHXLiquid
[IMG]]http://i58.tinypic.com/vxgjmg.jpg[/IMG]
PHXSource
Wine
and PHXSource.
Thank you.
PHXLiquid
PHXSource
Wine
