Black dots
  • Black dots
    anyone knows why these black dots appear? this geometry is outside the buidling and sufficiently lit and even has enough sub divs but these black dots look weired even with subpixel mapping checked
    Intel core i7-5960x cpu @3 GHz, GeForce GTX 970
    Would it be possible to send us that scene or a part of it which still reproduces the issue for investigation?
    Thank you very much in advance.
      hmmm, if i can find it , i doubt it very much, i changed many things in this file, was hoping to get a faster response but i get everyone is busy. thanks again for responding however there are new troubles with the vray multimatte render element when rendering a animation, sometimes it works and sometimes it doesn't, its driving me crazy. is there a known problem with this? i will prepare a file so you can test
        You'd probably get a faster response in the main forum instead of the demo one.
          the plugin rendermask has been discovered, no need for multimattes now i think
