Good evening. I really need your help, guys.
I had a scene made in Phoenix 2.1. I had to use newer version because i met the artifact and couldn't handle this by using other approaches except installing other version of plugin.
But when i installed it, there was a big difference between simulations. At these screens i showed the difference. 2.2 is creating many less particles with other simulation results unlike 2.1. Is there is anything method for equal transfer calculations from 2.1 to 2.2 with no big difference? I have real big scenes and i have no time for much editing again.
This is 10th frame from 2.1
This is 10th frame in 2.2 (there is almost no particles, only if i increase splashes burn rate, something is appearing but anyway it is not the same result as i need)
