Vray ignoring Rhino (and vray?) lighting settings
  • Vray ignoring Rhino (and vray?) lighting settings
    Hi all,
    I have been thus far unsuccessful at getting Vray 1.5 to accept lighting input from Rhino 5 64-bit using: Rhino's Directional Light and Vray's "Set sunlight system" (and prob others).
    However, I have had some luck setting a rectangular light following a tutorial I found online, but this is not giving me the lighting I want, its only providing me with a 12 o'clock shadow type lighting setting, where I would like to create sunset/sunrise and different colors, etc., etc.
    Is there something I'm missing here? Does v-ray ignore rhino light settings by default? Why when I create a sun light system from the v-ray lighting panel is it also ignoring that?
    VRay starts with a setting if 1 for global illumination. That is a good bit of light. It will need to be turned down to see the other types of light.
    SH
    Let there B3D
    Steven Houtzager
    Intuitionusa.com
    3D Renderings & Animations for Product Development and Retail Design - Atlanta, GA
      Ok, is there an online wiki with lighting info? or is any/all lighting info explained in the F1 help perhaps?
        I have found the courses on Lynda.com to be the best.
        Let there B3D
        Steven Houtzager
        Intuitionusa.com
          Excellent, I do have lynda access, infrequently. Is the courses you're referring to Rhino 5 or V-ray specifically?
            Ray 2 in Rhino 5.
            Let there B3D
            Steven Houtzager
            Intuitionusa.com
