Scene Crash
  • Scene Crash
    can you please check why my scene is crushing?
    thank you
    here is a link to the file:
    http://we.tl/5J7lG0C4OK
    can't reproduce it, can you tell the build info?
    ______________________________________________
    VRScans developer
      it's 2.2.5 nightly build ID: 1512086525
        ok, what is happening? is it crashing during the loading, the simulation or rendering?
        VRScans developer
          it crash the moment i click the start button.
          sometimes immediately some times after 1 or 2 frames.
          it basically happens the moment that there is interaction between the particles and the can.
            can you attach the log file? use the about button to reach it
            VRScans developer
              i managed to solve it by flipping and unifying the Normals and performing Reset Xform on the model of the can.
              but now i can't get a decent simulation.
              i'm trying to fill up the can, then start simulating the pour.
              i can't find a way to make an initial state. i tried to simulate with static can until frame 50, then load frame 50 with load& start. but the particles are deleted very fast.
              when i try to simulate from frame -50, so the simulation will actually start in frame 0, the result of the simulation is very chunky and very water like.
              can you simulate it and post the file so i will see what am i doing wrong?
                create an object that defines the init fill up area, right click it, select phoenix fd properties, and enable the "initial fill up" uption
                VRScans developer
                  Yes, exactly what I did.
                  Tge simulation is looking very bad and there is no initial State.
                  These are two separate issues.
                  First tge liquid simulation looks chunky and not like liquid.
                  The second is that i need to letbtge liquid to relax inside tge can berore starting to simulte. But there isn't an option to simulate an initial state over one frame. Like in max cloth simulation for example
                    there is a button load&start, it does exactly this.
                    about the simulation issues,when the liquid does not behave smooth enough, you have to increase the spf, or to use bigger scale. in our beer sample scene we use bigger scale to avoid incredible high spf, in the most cases nobody notices that the scale is twice bigger. but the main parameter that gives "low scale" behavior of the liquid is the surface tension, set it to 1.
                    VRScans developer
                      the load&start is not exactly doing that.
                      in my case the can is animated. so i need to let the liquid to calm down while the can is not animated. so what i'm looking for is a button the simulate local, over and over again in frame 0. like it is in realflow or in max cloth sim. so the final result will be that the liquid calmed down in frame 0 and then i can start simulate while the can is moving around pouring the liquid.
                      i've tried a work around where like this:
                      1. i duplicated the can and deleted the animation.
                      2. i simulated with non animated can until the liquid calmed down (frame 50).
                      3. i brought back the animated can and hide the static can.
                      4. using load&start, i've loaded frame 50 to start and simulate from frame 0.
                      this method failed because when using load&start the liquid appears in frame 0 not the same as it was in frame 50. then the liquid particles slowly disappear like something is killing them.
                        i see now, we can add this functionality in future, but for now you have to do this manually, disabling the animation of the can
                        about the disappearing particles - i think your geometry is open, phoenix supports open geometry, but the liquid must intercat with the face side of the mesh, not with the back side like in your case.
                        in general, it's always better to use closed geometry. i think the easiest way to fix this is to use thin shell modifier.
                        btw, why you need to simulate the liquid inside the can? it's not a bottle, you can't see it, the usual technique is just to create an animated source at the can hole.
                        VRScans developer
                          the behavior of the liquid look more realistic when it is being poured from a filled object rather then from emitter with constant stream or even animated emitter with animated velocity
                            mmm...but the scene is still crashing.
                            here is a link to the updated scene:
                            http://we.tl/ZKqBL2CcdT
                            it crash after simulating 1 frame
                            • #15
                              ok, i will try it again, but we can't always reproduce the crash, that's why we have logging and many times we fix the bugs using only the log. attach it please, to have at least info where the problem may be
                              VRScans developer
