Hello,
first sorry for my bad english
Here is my problem, i am using Sketchup 2015 with V-Ray 2.0. I crated a very simple Material that contains a Reflection and a Diffuse Layer
with a Wooden Texture in the Map on the Diffuse Layer and a Bump map on the Maps layer. Pretty everything is on standart setting exept from Glossiness
Whenever i apply the Meterial to a survace its look okay in some areas but betwen those areas it makes some very strange stripes as you can see in the attached Image
The right side and the left side are just flat surfaces. The other image shows a overwiev of the Material.
The V-Ray setting are loaded to default for this Render
This Problem only comes up when i Create the Material in the V-Ray Material Editor, or when i load premade Meterial for example from http://www.sketchuptexture.com
As soon as i just import the Texture jpg direkt with import as texture option from Sketchup and modify the Material afterwards with the V-Ray Material Editor it seems to be fine so far.
