VRayRT 3.30.04 -> Render To Texture Issues
  • VRayRT 3.30.04 -> Render To Texture Issues
    Has anyone used CUDA/GPU in VRayRT for baking maps in Render To Texture? I can't seem to find a solution that works.
    My setup for using VRay Adv baking in Render To Texture was as follows:
    AO Map:
    -Mesh has VRayLightMtl assigned, with VRayDirt in the Color slot and VRayColor in the Opacity slot
    -Output Element in Render To Texture is set to VRayComplete Map
    -Render To Texture then produces a clean AO map
    In an effort to save render times, I tried carrying these settings over to VRayRT, using CUDA (since I've read GPU rendering is faster than CPU). But it does not yield similar results. The AO map is rendered in with multiple colors and corruption throughout. It also takes much more time to render (1min on VRayAdv vs. 20min on VRayRT using CUDA).
    If anyone can share some insight on this, it would be appreciated.
    If I have to guess, maybe you've left the Adv with default settings (1 min rendering with progressive) and then default settings for RT (noise threshold 0.005) which could explain the render times.
    About the differences - is it possible to send us the scene ? (peter.matanov@chaosgroup.com)
    Peter Matanov
    Chaos
      Not sure yet about sharing the scene, but what RT settings would you recommend for baking an AO or light map?
        Try with threshold 0.01 and if it's noisy - lower it until you reach а more satisfactory result.
        Peter Matanov
        Chaos
