Problems converting 3ds max vray materials to sketchup vray materials
  • Problems converting 3ds max vray materials to sketchup vray materials
    I´m having a lot of problems trying to find a good way to convert vray materials from 3ds Max to Sketchup. In 3ds Max 2016 I´m using vray 3.2 and in Sketchup the latest vray demo. The vrmat converter script is supposed to save vrmats for Sketchup which I´m supposed to import. The problem is that this works not at all. Maybe the materials are too complex, but so far I´m not getting any serious results.
    In the original scene I´m having a multi-sub material with 5 ids (for a tree with different materials for trunk, branches and leaves). Each of these leaf materials is 2-sided and contains sublayers. When exporting such a material (either as single or the whole scene materials), the loaded material in Sketchup contains hundreds and hundreds of materials (one for every leaf of a tree) that are basically empty. No textures are assigned correctly and none of the layers inside of the materials translate.
    I was hoping to convert an entire tree library to Sketchup with vray, but so far I´m stuck and don´t know if that would be possible at all.
    Creating the materials from scratch is not really an option since after spending 2 hours trying to recreate these materials in Sketchup I gave up.
    Any one know a good method how to convert materials ?
    Ah, I´ve also tried to export a vrmesh and use this for the materials, but that doesn´t work either ...
    Please help ... I´m lost ...
    About VIZPARK - www.vizpark.com
    VIZPARK is a Autodesk authorized developer of 3Ds max plugins and high quality 3D models for professional 3D artists.
    I am not familiar with how they export vrmats from 3dsmax - have you tried posting in the 3dsmax forum? They might be able to help you more. But in general there are complications with exporting materials from 3dsmax. V-Ray can only really export V-Ray specific textures and materials. So if your library makes heavy use of 3dsmax procedural textures, or other non V-Ray plugins, they will not really translate well.
    Joe Bacigalupa
    Developer
    Chaos Group
      Hi Joe,
      thanks. I found out that the 2-sided material causes a lot of problems and using a multi-material as well. If I try to convert the vray material itself (without being embedded into a 2-sided and multi-material) I can at least re-import this as vrmat into Sketchup vray. There are more issues, for example the scaling of textures / bitmaps. Once applied to geometry in Sketchup, I need to set the uv scaling to 0.01 in order to work, while the original imported textures from a FBX file work fine. So I guess there are several issues that are not addressed. The procedural textures within the vray material in 3ds max are not a problem as it seems. I´m just using gradient maps and fallof maps.
      So, if you have a chance to look at the export script, I think it would really help many others.
      Thanks,
      Martin
        Since going from 3.0/3.3 materials to 2.0 materials its not currently designed to translate 1 to 1. Vrmesh files also do not support material export.
        That said, there are some third party plugins that do help solve this issue, for example: http://www.simlab-soft.com/3d-plugin...-3DS-main.aspx and tutorials on how to do it manually like this one: http://www.dbrenders.net/#!From-max-...f24874170eb290
        I would also suggest either posting this in the Max forums or contacting support@chaosgroup.com with a clear outline of the functionality you expected to see in the exporter and a description of the bug that you have come across with the exporter not working.
        I hope this helps, if you have any additional questions please let me know.
        Best,
        Ted Vitale
        V-Ray for SketchUp
        Product Manager | V-Ray SketchUp
        Chaos Group
