These images are crops from renders with the same settings, one of them is slightly higher resolution. The filter (no matter which one I choose) stops working at a certain resolution, which is different for every scene. Simpler scenes can get higher resolution before the filter stops working.
This is a problem because the filter produces nicer images by making noise more natural and smoothing high contrast areas and sharp highlights, this can't be done in post. I can't use it for 5K resolution images.
Left is 3150x1772, right is 3100x1744, exact same settings. Tested on 3.30.04 and 3.30.05. I have not found anybody ever mentioning this problem anywhere. Tried remaking different scenes 3 times and resetting the settings, no luck.
Would be nice to know why this happens, and if anything can be done to fix it.
