is it a bug? when i right click the object and click "phoenix fd properties" and the message jumps out.is it a bug? how to fix it? i've uninstalled and re-installed it again,but the problem isn't solved.[IMG][/IMG]
In your other post Ivaylo already added a suggestion, but you may also try deleting the mcr file which gives you the error and let 3ds max generate it again. This problem is fixed in the nightlies.
