why is "vray property menu" disappeared in vray 3.3
  • why is "vray property menu" disappeared in vray 3.3
    hi,i'm using vray 3.3 in 3ds max 2016.i found a problem about it is that when i right click the object ,i can't fine" vray property" in the quads,i don't know why.could you tell me how or where can i find it?[IMG][/IMG]
    Hello,
    Try this:
    Customize -> Customize User Interface -> Quads
    Select VRay as your Category, now you can drag and drop different actions to the container on the right.
    The container on the right displays all actions that are present in the quad menu.
    Hope it helps
    Martin
    https://www.flickr.com/photos/147558...h/31460898213/
      Hello,
      You could use the registerVRayMenus() command in the MaxScript listener - it will add all the menus.
      Yavor
      Yavor Rubenov
      V-Ray for 3ds Max developer
        it works,thank you.
