How to create paintball effect
  • How to create paintball effect
    HI We animated a sphere that hits a wall. is there anyway for sphere to hit a wall and burst or become paint and leave a nice splatter?
    Thank you
    and splatter to look like classic paint splatter with streaks
      i think yes (with nightly build), you have to enable the wetting, and to adjust the sticky param and the liquid consumption of the wetmap particles, after that you have to use the wetmap as mask for a blend material that has the pain in the slot corresponding to white mask. for more details see the scene in this thread, it shows how to use the wetmap for material blending
      ______________________________________________
      VRScans developer
        Thank you
        Are there any best setting for classic splash with streaks coming out. We did wetting but it looks like a round pancake on a wall and not splatter. Multi-pass makes it better but paint is just pouring out from that splash makes it look like splash has 10 times more mass than original paintball Thank you
          I would make the scene a larger scale or adjust the scene scale of the simulator. Surface tension and high SPF would help get the streaky long arms of splat
          Adam Trowers
            I cannot find this button anywhere "adjust the scene scale of the simulator" is it time scale?
              It is most likely in the nightly builds. I assume you are on the official build?
              Adam Trowers
                Hi We are trying using 2.2 demo version
                  this makes your chances significantly lower, the demo has no wetmap, and uses the fire/smoke solver to simulate the liquids
                  VRScans developer
                    Thank you
                    I know chaos group does not sell directly. When we buy phoenix through third party how do we get updates, nightly builds etc.
                      Contact support, they will ask you for your dongle number etc and then give you access to the FTP site
                      Adam Trowers
                        As flipbook said just contact us after the purchase and give us your username or dongle ID and we will provide you with nightly build access.
