Maya Fluids -> OpenVDB -> vrayVolumeGrid
  • #16
    Any update ?? And in older version ..if VDB cache size is big (1GB-2GB per frame) and network is slow thn vray starts to hang plus Maya crash on farm..Any plan for workflow optimization ??
    • #17
      Hey,
      Does the crash happen consistently? If it can be reproduced, can you contact support and send over a scene and a cache with which it crashes?
      Regarding workflow, I'd say give the Phoenix 3 Open Beta a try - https://www.chaosgroup.com/phoenix-fd/maya . Phoenix caches are way smaller than VDBs of the same resolution and thus load and save times are better, there is a viewport GPU preview and you don't need to tweak the render settings twice because the Phoenix volume shader is the same thing that powers the VolumeGrid.
      Cheers,
      • #18
        Nope,Only when network get slow
        Right now here pipeline is Houdini based, So we do sim in pyro >> Export VDB >> VrayVolumeGrid
        In future version of Vray, viewport GPU preview for volumeGrid will be supported (without phoenix) ??
        • #19
          Affirmative, it will be
