Quick select objects by assigned material (also if it is a glass)?
  • Quick select objects by assigned material (also if it is a glass)?
    is there a quick way to find, which objects have specific assigned materials?
    Found on search:
    "WSelect the material in the Material Editor.
    Go to Utilities in the material editor's menu.
    Choose Select Objects by Material."
    But...nothing happens!
    Besides I have also different glass materials, that I simply cannot see in my scene.
    What I want to do is to select a specific material (in material editor) and see all objects that have this specific material in my scene. Any good advice?
    After you press on Select Object By material, the "select object window" appear with selected objects highlighted, than you have to press Select.
    To see Glassy objects in the Viewport the best option is to Right-Click on them and than click on See-Through, not really a pratical way but often needed
      To see Glassy objects in the Viewport the best option is to "Right-Click"->"Object Properties..."->and than click on See-Through (missed a passage before)
        Thank you!
