hi,i want to simulate dense smoke in phoenix fd 2.2.i found i can't load the preset file:bigsmoke.apr.but in earlier version,i can do it.how can i do it in phoenix fd 2.2?
how to simulate heavy smoke without fire?
there are two ways, use uniform density (see conservation) and negative smoke buoyancy, or use non uniform density and temperature below 300 , for example 100.
these approaches will produce different results, just select the one you like more.______________________________________________
VRScans developer
