how can i make smoke run faster and fill the objects
  • how can i make smoke run faster and fill the objects
    Hi,everyone
    Another question comes up again.i want to fille the 3 objects in this scene.the smoke runs very slowly in "M",but much faster in"A"&"X".the two letters are full in 100 frames.the letter "M" can't be filled.i don't know why,can anyone help me?[IMG][/IMG]
    the way in the M letter is just longer than in the other letter, and even the strongest conservation looses its power.
    if you are using nightly build i would suggest to drive the smoke by a spline, this will ensure uniform speed, beside this you can add some rotational movement
    ______________________________________________
    VRScans developer
      how to add some rotational movement,please?[IMG][/IMG]
        For this scene I used a few emitters in each letter to overcome the problem that the M is longer than the other two. I can try to dig up the scene.
        Georgi Zhekov
        Phoenix Product Manager
        Chaos
          Here is the Max file for the scene - just adjust your sim resolution and you should be good to go.
          Georgi Zhekov
          Chaos
            thank you.i've thought the conserve parameter could not fall off.
