how to make cloud with phoenix fd?
  • how to make cloud with phoenix fd?
    hi,today i want to create cloud with phoenix fd.i'd adjusted the temperature in PhoenixSource to 273.i thought it's ok to simulate the cloud,but the cloud still looks like liquid,which parameter should i change?
    Hey,
    Could you share a screenshot with your settings? Phoenix 3.0 has a Clouds Quick Setup preset in the toolbar, but if you decide to emit the cloud from geometry, it should definitely not behave like a liquid at all
    Cheers!
      this is what i set:[IMG][/IMG],[IMG][/IMG]
        In Phoenix the real 0 temperature is 300. If you set it below that value the smoke will fall down.
        But if you need clouds , just turn off the temperature for the source and the gravity from the simulator. This should do the job.
        Georgi Zhekov
        Phoenix Product Manager
        Chaos
