more foam
  • more foam
    how to make more foam at the passage of a vessel?
    and it is possible in a static position to give tracks on the water (foam) the ship?
    You can make more foam by increasing the foam birth rate. You can find more about foam generation here - https://docs.chaosgroup.com/display/PHX3MAX/Liquid+Foam
    If your ship is static and you need foam in the pattern of tracks you can make a texture mask that emits liquid and foam.
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      I'm sorry I'm a noob, and looking for a very prompt about texture mask that emits liquid and Foam
        simply put Box before ship and appoint him liquid source(ship static)
          You just set the Emitter to use a map for the particles and set the type of the particles to be foam. Here is a sample scene.
          Georgi Zhekov
          Chaos
            Can you demonstrate to having your ship static? I think for many it would be useful to know. I just do not understand how you created this texture
              with texture, I realized I do not understand how the texture should guide the foam in motion
