foam
  • foam
    Dear developers, you could throw the scene in which the foam is formed and the spray from the object to the position of static? I will be very grateful
    just the past few days it has spent ...
    can you clarify the question?
    ______________________________________________
    VRScans developer
      I have a very large drill ship
      1 I do not want him to move
      2 want that used water itself moved, and formed a sea trail
        whether it is possible to make so that the vessel used in a static position and made the foam spray? (as if the water was on the ship)
          i see now, you can use the wave force to create waves that will interact with the oil platform
          VRScans developer
            My foam enters the ship
            how to make sure that it goes only to the outside, and it was not within the
              if the original render geometry is not suitable for simulation, you can use simplified dummy geometry to represent the real one in the simulation, this approach is widely used in the fx area
              VRScans developer
                how add pg(splashes) or pg(foam) of system(phoenix) in particle systems?
                  when I add, adds phoenix FDliquid
