Geometry lines on render
  • Geometry lines on render
    I'm trying to use VRAY to make a render with SketchUp. This is my first time with VRAY.
    The result is good but I get some problem with terrain model.
    As you can see there are some lines on terrain:
    Model
    Render
    How can I remove it?
    Are you using V-Ray Displacement? Turn on the V-Ray displacement parameter called 'keep continuity' to get the render to continue the displaced surface between non-coplanar surfaces.
      Yes I use displacement but the "keep continuity" is active:
      V-Ray material:
      Render:
      Any ideas?
        Try to soften/smooth the edges of the terrain.
          How?
          I just try to click with right button of mouse on terrain, select option to soften/smooth, change value.
          In this way on SketchUp I don't see geomtry lines any more but on render I see my of these (not all).
