Smoke rendering
  • Smoke rendering
    I am trying to simulate smoke going through car grill with relatively small openings, but the smoke is not going through the grill. how can i fix this?
    Thanks
    Hey,
    You should either increase the size of the openings, or increase the grid resolution a lot, so that each opening is bigger than a voxel. You can also try setting the Voxel Type to Inscribed from the Interaction panel.
    Hope this helps!
      Well, i can't modify the car model as it is a CAD model. but i can try the other solution. Thanks a lot
        in all the cases with complex geometry it's a good practice to use not it directly, but low poly representation, this makes the simulation setup easier, and the simulation runs faster
        ______________________________________________
        VRScans developer
