VRayVectorDisplBake
  • VRayVectorDisplBake
    Hey Vlado,
    In Vray 3.4 for 3dsmax there’s a utility called ‘VRayVectorDisplBake’. I can’t find the same utility node in Maya. Does this exist in Maya Vray or will it in the future? We are running 3.30.02.
    I didn’t see anything in the change logs for subsequent Vray Maya versions but I could have missed it.
    Thanks,
    David
    David M. Foster
    No, we don't have it in Maya although it's fairly easy to code it... can you explain a bit what you want to do with it?
      Hi Vlado,
      Thanks for your quick reply. We have a fairly intricate object that we'd like to generate a vector displacement map for. We're hoping to point V-ray at a plain and the object, and generate the delta. My understanding is that the VRayVectorDisplBake utility provides that exact functionality -is that correct? Or is there another way to achieve this?
      Thanks for your help.
      David
      David M. Foster
        Is the base object specifically a plane? There might be ways to do that in Maya as it is, maybe involving reference meshes or something.
          We have the transfer maps tool between a source and target mesh, but this only supports regular displacement. Is that the tool you are thinking of?
