Hey guys!
I need some help with the VRay Infinite Plane in Rhino 5.
We do a lot of exterior renders of boats and we are striving to achieve a realistic view of a yacht on the ocean with a horizon and realistic sky.
Ultimately we want to use a HDMI on a Dome Light, because this gives a realistic sky and lighting that relates, with an Infinite Plane for the water texture, so that the water runs and meets the HDMI at the horizon line.
This is where the problem comes in, I have created a water texture that works really well on a circle plane, but it gives the wrong horizon line.
When I apply the same material to the Infinite Plane it renders completely flat without any texture (I have checked and reapplied the material).
I also understand that Rhino sees the plane as Infinite, is there a way to over ride the 'Infinite' part of the Infinite Plane and apply the same measurement parameters to it as the smaller planes?
I would also appreciate any comments on if there are better ways to set up an exterior scene for the ocean
Thanks for your help in advance!
