Units
  • Units
    This is a question I've always pondered but never had a solid answer to...
    I model in Rhino in mm (millimeters), and render with Vray in mm too. I do archviz, which means I have quite large scenes (but physically and in file size/polygon count.)
    Each time I render with vray, the progress window gives me the following warning:
    "Scene bounding box is too large, possible raycast errors."
    Is this a problem? Or can I ignore it?
    Should I not work in mm for vray rendering? I ask knowing 3DSmax users generally use Meters.
    Any tips/feedback appreciated!
    Tremendously late reply.. but nevertheless, I just wanted to drop by to say you can safely ignore the warning.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
