Point World Reference Pass with Yeti Fur?
  • Point World Reference Pass with Yeti Fur?
    Hello,
    We are rendering a fur covered face in Maya 2016, using Yeti v2.1.7 & Vray 3.40.06
    All the Vray passes are working, but we are trying to use a "point world reference pass". We have found a great example here with a tutorial on how to create it.
    http://erwanleroy.com/create-positio...vray-for-maya/
    Is there a special node that one would use to find the world position of the fur, or is it just a limitation for all?
    We have a texture reference object created for Yeti, of course, but it doesn't seem to be "seeing" it as one?
    I don't know if anyone would have any ideas of how to do this?
    So what's the issue exactly? I just tried it and I can see the fur in point world reference. Does it not animate correctly for you?
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Exactly! In my test scene, the yeti fur renders as if its traveling "through" the world colors. What exactly does your setup look like?
      I was told to connect the SamplerInfo Node in the "default color" of a VRayUserColor node with an attribute called referencePosition. That way it looks for the custom attribute "referencePosition" specified in an attribute node after the "grow" nodes in my Yeti node graph.
      I must be missing something.
        This is what I suggested, yes. I was told that Yeti generates a "referencePosition" attribute on the points, which you can read with a VRayUserColor node.
        However I didn't get a chance to actually test that as I'm not sure if I need to do something specific to make Yeti generate the referencePosition data. Will try to play with it tomorrow.
          We were wondering if you had had a chance to play with the Yeti/Vray situation for the Point World Reference Pass?
            Attached is an example. Look at the Extra Tex render element - is this what you are looking for?
              YES! Thank you so much Vlado! It is totally working and my compositor is using the pass as we speak. Very good solution.
