Problem: Dome light showing only when interactive rendering
  • Problem: Dome light showing only when interactive rendering
    Hi all,
    I have a problem with rendering with v-ray 3.0 for sketchup 2017 and dome light.
    I have added a dome light in my scene, to iluminate my interior space.
    what happens is, when i render with interactive rendering, my picture looks like this:
    which is what i want, but when i render with bucket rendering or progressive rendering, it just ignores my domelight ilumination, it looks like this:
    does anybody know what may be the problem?
    P.S. evne when i click interactive rendering, it first shows the darker image (without dome light) and i have to uncheck and check ENABLED at domelight settings to get it working again..
    thank you for your help,
    M
    I guess you are being ignored by the Chaos folks?
    I had a similar problem -- everything looked ok with progressive and when I switched to normal for final render - the sun light no longer came trough the windows.
    I though that VRAY for SketchUp would eliminate all of the frustrations that are a part of rendering LIGHTED interiors with 3DS Max / Mentalray...
    I was wrong.
    Intel i7-980
    ASUS X85 LGA 1366
    NVIDIA GTX 980 4GB
    24GB Corsair Vengeance DDR3
    Intel 520 Series SSD 240GB SATA III (OS/programs)
    Intel 320 Series SSD 160GB (Data)
    WD Raptor ATA 300GB (Data)
    Win 7 Pro 64
    HP ZR24W LCD
      Hi
      Maybe tick off Max Ray intensity(in production rendering mode)will help?
      If I am remember it correctly, MRI is tick off in Interactive rendering mode.
        Hello,
        I was unable to reproduce the problem.
        There shouldn't be any difference between Interactive and non-Interactive rendering in terms of final output image. Neither should there be any between Progressive and Bucket modes.
        Could you please advise whether what you experience occurs only in this specific project or in any others as well?
        What is your OS and full version number of V-Ray for SketchUp?
        Kind regards,
        Peter Chaushev
        Peter Chaushev
        Let's keep in touch
