Vray trial buggy/ freezing
  • Vray trial buggy/ freezing
    So I've downloaded the trial version after getting used to and liking the beta version.
    Yesterday everything worked fine. But now when I want to render Vray freezes rhino. No Frame buffer window opens. Nothing. Every time I have to force quit Rhino. This happens with Render, Interactive Render and Export Vrscene.
    So its pretty much useless at the moment.
    Any Idea what I can do to solve this problem? Apart from uninstalling and reinstalling.
    Additional Info: I think it has something to do with the Render History screen. Thats the first thing that pops up when I press "Render" and it wont be closed.
      If you could not render at all that looks like a licensing issue. What do you see when you type localhost:30304 in your internet browser? Can you share a screen of that?
        Hi there,
        I have exactly the same problem where when I want to render the frame buffer screen along with the render history settings screen appears. The screen buffer only stays black and nothing appears to render. Then sketchup crashes and I need to close the file. I've been using the trail version for a few days now and everything was working fine - until suddenly this happened. I've reinstalled the vray trail twice now and still have the same problem. I was planning on purchasing a vray licence - but now I am scared that this problem might continue.
          Originally posted by stelliewag View Post
          Hi there,
          Hello,
          Please go to %APPDATA%\Chaos Group\V-Ray 3.4 for Rhino and delete the file FrameBufferState.fbs . This will reset the VFB history settings and you should be able to render without a problem.
          Do you recall any of your actions right before producing the issue for the first time? Any info about it would be truly appreciated!
          Kind regards,
          Peter Chaushev
          Peter Chaushev
          Let's keep in touch
