Default windows size, default file type when saving
  • Default windows size, default file type when saving
    Are there any files that I can modify, in order to change the default window size and the default file saving format?
    Thanks!
    Please, anyone?
    I have a 4k monitor and everytime I open Vray it looks like this:
      Hello, Isarescu,
      At the moment, I can only advise you to use the Windows display scaling. There are no other viable workarounds.
      Kind regards,
      Peter Chaushev
      Peter Chaushev
      Let's keep in touch
        The v-ray asset manager looks right scalewise? I don't know how big your monitor is, but the small fontsize suggests it is big! So what would you like to be bigger? Not that I can give you a solution, sorry. I'm just curious
        I work on a 27" 5k imac and the fontsize is much bigger.
Name:	Screen Shot 2017-04-14 at 08.22.03.jpg
        edit: the attached image was scaled down.
        Best,
        Peter
        AMD Ryzen 9, RTX 2080Super, ArchiCAD 24, Vectorworks 2020, Sketchup 2021 Pro, Vray Next for Sketchup, Skatter, Twinmotion 2020
          I`m working on a 32inch 4k monitor. The problem is not with the fonts (solvable by scaling), but with the actual window size and the fact that I have to resize it every time I open a new Sketchup file.
            Hello again, Isarescu,
            The inability to resize the V-Ray Asset Editor horizontally is by design.
            Our developers will look into the possibility to save the Asset Editor dimensions not only during session, but also between sessions. The changes would be saved only on the machine and not in SketchUp project files.
            If this is approved and implemented, it will be introduced in the next big update for V-Ray for SketchUp.
            Kind regards,
            Peter Chaushev
            Peter Chaushev
            Let's keep in touch
              That would be great, thanks!
