VRayClipper - Set material ID
  • VRayClipper - Set material ID
    I'm having trouble understanding how the "Set material ID" and "Material ID" parameters of the VRayClipper work. Could anyone explain and give me an example to reproduce?
    Thank you
    Daniel R. Reple
    Hi, did you check this manual?: Mesh Clipper | VRayClipper
      Hi filibis,
      yes, I did! And tried to reproduce some things I found, but they were from vray for 3DS ...
      This was one of the few materials I found on the subject:
      https://www.youtube.com/watch?v=RBxGDz8CTxU
      But didnt work here!
        Originally posted by danielreple View Post
        Thank you
        Daniel R. Reple
        Hello, Daniel,
        There are a couple of issue with the MeshClipper material ID parameters. Currently, they only partially work with Section Planes and not Mesh Clippers.
        This will be fixed as part of the redesign our devs are doing on the whole Material ID workflow. For now my advise is to use the Material parameter drop-down instead and disregard "Set Material ID".
        Kind regards,
        Peter Chaushev
        Peter Chaushev
        www.chaos.com
          Hello Peter,
          Many thanks for the info!
