VRay and PyroCluster 3.0 Not working properly...
  • VRay and PyroCluster 3.0 Not working properly...
    Well it's a pity that I can't post in other areas (it's a question of a day or two). So I installed this cebas (I know that you're thinking ) plugin and then - I tried to render scenes included in package. Scanline, mental, fR.. even Brazil - no problem. VRay -=- I don't see volumetric shading at all...
    Seems like VRay just don't calculate Light interraction between cloud and direct light that is in most of the scenes...
    CG Artist
    So there's still no answer....
    CG Artist
      Re: VRay and PyroCluster 3.0 Not working properly...
      NO takers? I am also interested in what you'd find out Paul.
      We're looking at this plugin for a current project...
      vertex wrangler
        did you anable the correct channels ?
        Natty
        http://www.rendertime.co.uk
          Which one ?
          CG Artist
            im not sure to be honest ... never tryed Pro cluster.. why dont you just make sure they are all used ...then you cant get it wrong !
            Natty
              OK. Did a quick comparsion...
              Scanline (20sec)
              VRay 1.46.10 (41sec)
              See the difference
              CG Artist
                sorry dude but as ive never used Pro cluster i cant really answer your question fully ... perhaps egz has your answer .. .. or perhaps it just doesnt work with vray .. not sure!
                Natty
                  I'm just curious - why it's all as cool as in scanline with Brazil and mental ?
                  CG Artist
                    dunno...maybe cause they are different renderers?
                      Are you using vrayshadows? if so try shadowmaps.
                      Eric Boer
                      Dev
                        All the shadow types are useless...
                        CG Artist
                          WHY IT's STILL quiet ?!?!?!?!
                          CG Artist
                            well maybe if you were a registered user...
                            Eric Boer
                            Dev
                              yeah. you should get ahold of the chaos guys and get them to add you to the normal forum so you can port this in the bug list. unless this is the vray_free copy then i dont think atmospheric plugins work. not that there is a 1.46.10 free version.
                              more or less i think that the sooner you sort out your registration problem the sooner you might get some answers.
