rendering issues - ./src/ocl_tracedevice.cpp(1867) : CUDA error 719 : exception occurred on the device while executing a kernel
  • rendering issues - ./src/ocl_tracedevice.cpp(1867) : CUDA error 719 : exception occurred on the device while executing a kernel
    I have only been using V-ray for a few weeks so I am very much learning. I have done 15-20 renders so far without issue but in the last 2 day I cant seem to render anything. the render starts and almost straight away it finished or crashes, the above was the last error message. the scene is the same as a previous render which worked fine, the only change is a single material change. I have tried other scenes, smaller models etc, interactive seems to work better but still crashes eventually. I have had other error message but the above is the last one.
    I have very limited tech knowledge and all this is a bit new to me.
    id be grateful for any help.
    thanks.
    Hello,
    Could you please provide some additional info about your problem?
    - OS version
    - full version number of V-Ray for SketchUp
    - Have you recently updated your GPU drivers and what version are they? What is your GPU model?
    - Does the issue occur only when trying to render specific files?
    - When SketchUp crashes, please leave it closed, then open the folder Users/.ChaosGroup/V-Ray 3.4 for SketchUp and see what is written in the file VRayForSketchUp.log.
    You can send all of the requested info to support@chaosgroup.com so my colleagues can help you out!
    Kind regards,
    Peter
    Peter Chaushev
    V-Ray for SketchUp | V-Ray for Rhino | Product Owner
    www.chaos.com
